Is it possible to use the M3 fenders on a 325i withou replacing every other panel on the car? I probably need at least the door panels. I was wondering if i t would be an easy swap to get some more clearance for some wider rubber, or should I just pull the fenders?
M3 body panels
dont forget the doors have no rubbing strip tho.Originally posted by franzI believe the doors are the samesigpicM42 Brigade ... Throwing craze in the 318Comment
If i'm not mistaken only the hood and the sunroof are the same. I think this has been covered before as well.Comment
Originally posted by Avus_325isIf i'm not mistaken only the hood and the sunroof are the same. I think this has been covered before as well.
"See, we're adding a little something to this month's sales contest. As you all know, first prize is a Cadillac Eldorado. Anyone wanna see second prize? Second prize is a set of steak knives. Third prize is you're fired."Comment
Front fenders will bolt on, rears will have to be grafted. Doors are different (molding). The rear valance/license plate sheet metal area is the same for M3's and pre-88 non-M's.
Why do you think you need to clear larger rubber? You can stuff 225's under stock fenderwells in a non-M, how much tire do you think you need? For the car in your sig, you won't need more than a 205 or maybe 225.
Seriously, you've got all of two mods that do close to nothing for your power. Don't worry about huge rubber.Originally posted by Stu McFront fenders will bolt on, rears will have to be grafted. Doors are different (molding). The rear valance/license plate sheet metal area is the same for M3's and pre-88 non-M's.
Mirrors.Originally posted by e30MattOriginally posted by Avus_325isIf i'm not mistaken only the hood and the sunroof are the same. I think this has been covered before as well.
AaronComment
Aah, but some are body color and some are not. Grasshoppa. :)Originally posted by aaron_silvaMirrors.Originally posted by e30MattOriginally posted by Avus_325isIf i'm not mistaken only the hood and the sunroof are the same. I think this has been covered before as well.
Aaron
