Euro bumpers front valance question
  • Jean
    • 18228
    I picked up a set of e30 euro bumpers and the valance that was on the same car is metal, and uses a plastic lower lip with brake duct holes. Also, fog light brackets mount with 3 screws and sit flush with the valance.
    Was there more than one type of front valance for euro bumpers?
  • ethree
    • Aug 2007
    • 1216
    Yes. Sorry I don't know how many different types there were or when they made the design changes.
    • Jean
      • 18228
      Here is a picture -
      • hendrixvodu
        • Jan 2007
        • 2514
        Here is a picture -
        late model ...its like the plastic bumper valance equivalent.....i think 86 and up had them?
        -His-
        87 e30 325i
        87 e24 m6
        05 e83 x3
        94 e32 740i 5spd
        -Hers-
        89 e30 325i
        18 f48 x1
        • kronus
          • Apr 2008
          • 13032
          Yes, there were two generations of early euro valence. The earlier one (82-85) was flatter in the front. You have the later one.
          cars beep boop
          • Jean
            • 18228
            Is the early one the one-piece fiberglass is that an add-on aftermarket or oem piece?
            Also, does anybody know what the part number for the fog light delete covers for this valance would be?
            • JasonC
              Site Manager
              • 14451
              That there is the early one (82-85) it curves under somewhat. Where the later one is more flat looking. Also here's a hint, you can use a e36 M3 lip on that plastic lip. The e36 part has to be cut down and trimmed to fit it though.
              EDIT: real oem is showing 2 different part#'s for the fog light delete panels (#9)
              http://www.realoem.com/bmw/showparts...19&hg=51&fg=20
              1992 BMW 325iC
              1978 Chevrolet Monte Carlo
              • Jean
                • 18228
                Thanks! I wonder which ones actually fit the valance 51711906288/287 or 51711933767/768.
                Do you know of the lower lip or apron that I have here is specific to this valance? I had a similar lower lip on my 84 when it came with the diving board bumpers, it also had the brake duct holes and all.
                • JasonC
                  Site Manager
                  • 14451
                  It's the exact same lower lip.
                  1992 BMW 325iC
                  • Jean
                    • 18228
                    Got it. So the other M-Tech valance, not a sheet metal one, was also available as OEM item and NLA as well?
                    • Jean
                      • 18228
                      Guys, I want to order new plastic parts for the front euro bumper and I am confused why there there multiple part numbers for the same items.
                      http://www.realoem.com/bmw/showparts...33&hg=51&fg=15
                      10 PROTECTIVE MOULDINGS 1 09/1987 51111888266 $23.72
                      10 PROTECTIVE MOULDINGS M TECHNIC 1 09/1987 51111953715 $25.95
                      11 RUBBER STRIP LEFT 1 09/1987 51111888273 $27.06
                      11 RUBBER STRIP LEFT M TECHNIC 1 09/1987 51111953713 $32.09
                      12 RUBBER STRIP RIGHT 1 09/1987 51111888274 $25.67
                      12 RUBBER STRIP RIGHT M TECHNIC 1 09/1987 51111953714 $33.20
                      Whats the difference? How are the mouldings/ rubber strips that aren't marked with "M technic 1" different ?
                      • ethree
                        • Aug 2007
                        • 1216
                        This thread might have some helpful info:
                        • Jean
                          • 18228
                          http://www.r3vlimited.com/board/showthread.php?t=108107
                          Those are for the plastic bumpers looking at the part numbers..
                          • scabzzzz
                            Estado de mierda de encargo
                            • 6871
                            Well, the Mtech euro bumpers that fit onto the Mtech valence and great one piece is a big different in how it straps to the bumper itself. You can use euro bumpers from an mtech kit and vice versa but it doesnt bolt on the same. The regular euro bumpers like you have, will have the mouldings as snap in pieces, as opposed to the little screw type clips I believe on the mtech bumpers. So when you order parts, order for the non mtechnic.
                            As far as your pickup, JasonC is right. You have the earlier model units like I have. You can use any early lip on it US or Euro (same shit pretty much) as long as its not 86-87. So 83-85 will work. Those bumpers should be plug and play. One thing you will have a problem with though (at least I did) is the front turn signal lights. The connectors are different and wont plug straight in. I just left mine out.
                            I picked up an 87 model front lip that I'm going to fab up to the valence. It looks better in my opinion. For reference on what I'm talking about, check out Backtrail69's red sedan euro bumpered car. The early lips (83-85) always get warped and fucked after many hard years. I'm running what I consider to be the best condition possible and it still sags. Hope this clears it up. PM me if you have problems. I've been researching for a while and stocking parts for comparisons. :)
                            Here is a picture of what your front end will look like. I drive an 86.
                            Sloped front end with the early, early lip with brake duct holes.
                            • Jean
                              • 18228
                              Thank you. So to make sure I understand this, 51111888266, 51111888273, 51111888274 snap in and 51111953715, 51111953713 , 51111953714 uses screws to mount ?
                              Didn't know there were two types of chrome euro bumpers .
