Removing glass tinting
  • AV325i
    • Jul 2008
    • 104
    I'm looking at a nicd 325xi, but it has dark window tinting that is coming off on the drivers window. How hard is that to take off and replace? How do you get it off? It doen't look like it peals off very easily.
  • E30_Pare
    • 7801
    I took mine off with a razor blade and glass cleaner. Just get a piece in the corner to peal off then pull. After its off there might be some sticky residue left behind. Simply spray on the glass cleaner and start scraping it off with the razor blade.
    DREWLIENTE
    1$ PShops PM me
    • Tsweers89
      • 228
      use a heat gun. if you get it hott enough it wont leave behind so much goo. and makes it much easier than just a razor
      • AV325i
        • Jul 2008
        • 104
        Thanks for the tips. I was hoping that was the case.
        • John in VA
          • Aug 2007
          • 553
          Another method that works well when the sun is around:
          Spray the inner windows with ammonia, cover them with black plastic bags cut open, let the sun heat things up, peel it off.
          See:
          http://www.tintdude.com/remove.html
          • So Live
            • 2512
            Yeah, i was going to suggest ammonia. They always say to make sure any window cleaning products dont contain ammonia if you have tints cuase thats what the pros use to remove it.
            Good luck!
            -Chris
            • naplesE30
              • Nov 2007
              • 1839
              I used a steamer my wife has for clothes and it worked beautifully. I was able to peel both layers at the same time with little residue left. Then simple windex with amonia took the little remaining glue off.
              • monty
                • Feb 2007
                • 665
                Yeah use a steamer. My buddy owns a window tinting shop and thats what they use.
