Passenger seat belt doesn't unroll
  • sna77
    • Apr 2023
    • 206
    Anyone have a quick fix for this? The passenger seat belt seems to be locked up and won't unrolll...
    Thanks!
    1992 318i cabrio Alpinweiss 2
    2006 ZHP cabrio Imola​
  • It's Soda Not Pop
    • Jan 2022
    • 875
    Can you push the belt in more? Similar to a Chinese finger trap. Push in to relief the tension and it should come out.
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • sna77
      • Apr 2023
      • 206
      unfortunetley, it rolled up so far, it won't release at all. we've been trying for a few hours now. Ugh... If the seatbelt is toast, what are the options?
      • It's Soda Not Pop
        • Jan 2022
        • 875
        New belts if you can't get them out
        88' Seta 2.7i Zinno
        • bangn
          • Sep 2011
          • 760
          you will need to pull the belt out, hold in hand at the vertical angle as if it was mounted in the pillar, tilt it slightly whilst slowly applying pressure to feed the belt back in to try release the lock and try pull it out a slighly different angle than straight up. If its reeled all the way in then its new belt time
          Boris - 89 E30 325i
          84- E30 323i
          • sna77
            • Apr 2023
            • 206
            Doesn't look like the passenger seat belt is still available, ugh. Driver's is though:
            https://www.realoem.com/bmw/enUS/sho...01#72111935612
            • It's Soda Not Pop
              • Jan 2022
              • 875
              Is your e30 a sedan? I have front belts for a sedan
              88' Seta 2.7i Zinno
              • sna77
                • Apr 2023
                • 206
                convertible. thx though
                • It's Soda Not Pop
                  • Jan 2022
                  • 875
                  No worries
                  88' Seta 2.7i Zinno
