Rear seat belt receiver.
  • Stan
    • Jul 2019
    • 780
    So I got a little too aggressive with the heat gun and ruined my rear seat belt receivers.
    Got a set from an E30 enthusiast, cleaned them up and ready to install.in my 1989 cabriolet.
    Saw a YouTube on removing the rear seat. Seems simple enough.
    Question: once the bottom is removed, is the bolt holding the belts to the car obvious or must I also remove the seat back?
  • McGyver
    • 4637
    Extremely obvious. The receivers are like 6 inches long and dead-end into a bracket that is bolted down.
    Lift up on the front of the seat bottom to release the two clips (one at each side), then pull the seat bottom right out. Then you'll see the single bolt you need to remove.
