Difference between coupe and vert door cards
  • robrez
    • Jul 2008
    • 3376
    Hello, pardon my ignorance but I don't have much experience with coupes and verts (I have a 4-door). What are the differences between coupe and cabrio door panels (front and rear)? If they are different, can they still be interchanged? Thanks.
    January 2012 COTM
  • White325is
    • Oct 2006
    • 5947
    The rears cant be changed. The fronts from vert to coupe can be changed with a little work.
    On the top of the door card for for a vert its straight all the way across. on the coupe there is a little cut out for the pillar on the door.
    So when putting the vert panels on a coupe you need to pull the material back in the corner and trim the fiber board under and reglue the material then install.
    • robrez
      • Jul 2008
      • 3376
      Thanks for information. Another dumb question, how do the rear door cards differ? Can the material from a vert be swapped into the rear door cards of a coupe, or are they totally different shapes? Thanks again.
      January 2012 COTM
      • reelizmpro
        • 9534
        The rears have totally different shape.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • bmw325csi
          • May 2007
          • 4045
          ^ and a speaker in it.
          harry/harout
          • robrez
            • Jul 2008
            • 3376
            So, coupe door cards won't look right on a vert because the coupe panels have a cut-out for the pillar? Or is it unnoticeable?
            January 2012 COTM
            • SA E30
              • 1248
              Just look at an interior picture of both and it will soon make sense as to why they won't work
              • Hey-U
                • Mar 2008
                • 560
                I have coupe front door cards on my vert. It's not perfect but it works and I have never had a comment from someone who noticed. It wouldn't be hard to make unnoticeable.
                • robrez
                  • Jul 2008
                  • 3376
                  I was talking about the fronts.
                  And I did look at pics and the difference isn't readily apparent. Which is why I was hoping someone who did the swap would respond. Thanks Hey-U.
                  vert
                  coupe
                  January 2012 COTM
