m tech 2 wheel on air bag car
  • brn2ply7
    • 301
    Is it possible to put a m tech wheel on a air bag car. Is it similar to an aftermarket wheel where you have to use two non airbag wheel spacers or something?
    89 325i parts car
    90 325i in progress
    ground control 400f 700r-koni adjustables-koni adjustable sways-reinforced control arms-ground control camber plates-e36 cabrio shock mounts-4.10 lsd-5 speed swap in the works
    --tryng to join the schwarz army one day at a time--sigpic
  • tdoyle
    • Oct 2009
    • 40
    I have the same question. looking at a mtech #32332226086 to go on my 92 vert. the one the guy is selling has 2 wires coming out of it for the horn? I have no idea where they'd go!
    • sector6
      • 909
      I just put a tech1 wheel on a airbag car and did have to use an extra spacer. Haven't figured out how to hook up the horn yet though.
      • E30_fiend
        • Apr 2006
        • 7348
        what areyou guys all talking about? You dont need to do ANY wiring to make a non airbag wheel work on an airbag car. Take the airbag wheel off, set aside. Put the desired wheel on and add you other spacer on the front side of the wheel and put the nut on and torque it down. Your horn should work without any wiring being done. All e30 steering wheels work the same.
        • stumble_t
          • Aug 2009
          • 759
          spacer
          wheel
          spacer
          washer
          nut
          that is all.
          [IMG]http://www.r3vlimited.com/board/
          • sector6
            • 909
            Then why the fuck doesn't my horn work now, know-it-all???????
            • E30_fiend
              • Apr 2006
              • 7348
              you probably messed something up pulling the old wheel off. All the e30 wheels work the same. So unless you popped a wire off or you arent using an e30 wheel, everything should work right.
              The horn works off of a contact patch that completes the ground to the horn allowing it to make noise. So you probably have to make sure that you actually have an e30 wheel
              • stumble_t
                • Aug 2009
                • 759
                Yea there's a spring loaded wear pin in the center that makes contact on the brass ring on the backside of the wheel with conductive grease on it. also there is a little spade connector that connects the brass ring to the horn button/s make sure there is continuity there.
                • KamakaziX
                  • 2041
                  I know, I know. Old thread. Where does one acquire such a spacer?
                  Originally posted by lambo
                  Fuck studying. Party hard.
                  • reelizmpro
                    • 9551
                    home depot or other hardware store, dealership, junkyard, etc.
                    88 M3 - LACHSSILBER
                    89 M3 - ALPINEWEISS II
                    • JeST
                      • 639
                      I have a spare spacer at home. If you can't find one let me know. I'll ship it to you just cover shipping.
                      Current: 1988 M3 - Henna/Black black alcantara
                      Guten Parts + Service
                      ... When you care enough to only give the very best.
                      Previous:
                      '87 S50 MTech 1 325is
                      '07 DTM Audi S4
                      '03 VF Supercharged M3
                      '03 Lexus IS300 (615rwhp/512rwtq)
                      • Killacortes
                        • 1937
                        Non air bag cars have it. Or you can make one :)
                        r3v does not fuck around. First you get banned, then they shoot you
                        • KamakaziX
                          • 2041
                          Oh, alright. I could make one probably then. I thought there was maybe a weird spline or something.
                          • ScHpAnKy
                            • 1573
                            anybody got a pic of said spacer?
                            91 318i | 87 535iS
                            • davem
                              • Jun 2010
                              • 705
                              If you take your steering wheel off there is one there put by the factory. Find another one off a different car or buy one online and put it on the top side of the wheel. Works perfect
