One touch + e36 switches...
  • Sean
    • 5793
    Hey,
    I'll be buying some e36 window switches soon from a 328i that is being parted out. Before I buy, I'll be making sure the bottoms are white, not sure if they are or not.
    I was wanting to get the one touch module and retro fit that into my car too - does anyone know there this is in the E36, so I can tell him to grab that for me?
    Also - would that work to make my windows one tocuh in conjunction with the swithces?
    Help is appreciated!
    Thanks,
    Sean
    - Sean Hayes
  • Jand3rson
    • 37587
    If you're going to do the one-touch mod, you can't use the white base swtiches. I think the one-touch switches are green.
    • Sean
      • 5793
      Ohh, ok. Then i use the module with the green switches? Do the green switches illuminate too?
      AND - where is the one-touch module located? I haven't the slightest clue!
      - Sean Hayes
      • OOMPH!
        • 3487
        You might want to PM Nate.... "Nate325ic"
        • Bryson
          • 1490
          HAHAHAHAHA good luck
          one touch control mudule is under the glovebox -- it's got about 200 wires going into/out of it and is quite large
          • Sean
            • 5793
            Ouch. lol Why are there so many wires?
            If that's the case, how would I go one touch with E36 window switches??
            - Sean Hayes
              • 34847
              there are aftermarket one touch kits available.. not sure of any specific brands though. I'd love to have one touch for at least my sunroof, although all 4 windows would be pretty sweet.
              • Addissimo
                • Mar 2004
                • 1820
                autolok makes one... but you have to have a separate relay for each window and they're $40 a piece... i guess since you only have two windows its not a big deal, but i'm hatin the fact that i have 4 :-/
                -Addis
                Doing something M50 related? -> http://www.addissimo.com
                On Myspace? ->http://groups.myspace.com/r3vlimited
                BF2142 SN = BillyGoose
                • Bryson
                  • 1490
                  -Addis
                  you've got to do that with the one touch e36 switches pretty much
                  I thought about doing a full e36 harness into my e30, what do you guys think, has it been done?
                    • 37833
                    I saw not worth it, rolling down the window isn't that hard.
                    I am happy with my normal functioning E36 switches
                    Grover Beach, California
                    BimmerHeads.com
                    • e30sd
                      Fistee
                      • Jan 2004
                      • 5517
                      -Addis
                      a certain jimmy P has done it
                      • erik325i
                        • Jan 2005
                        • 3567
                        So, are the normal e36 switches just plug and play? The normal ones are white underneath?
                        • Jand3rson
                          • 37587
                          Yeah, you need the white ones, and some very entry-level wiring is required. You also have to enlarge the holes in the console a tad, but nothing too complicated.
