Door lock problem...
  • r0meyrome
    • Jul 2009
    • 218
    Its been a year now since ive actually gone through this problem and now want it fix.
    Locking from drivers door-locks/unloccks
    Locking from trunk- locks only passenger and unlocks immediately. Unlocking from trunk only unlocks the passenger/trunk
    im thinking the drivers door actuator is bad since its not locking/going down when locking from the trunk..which should lock all...
  • reelizmpro
    • 9558
    When you lock the drivers side does the actuator work or does it just lock manually? Clean the pins in the drivers door jamb connector first before trying a new actuator.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • r0meyrome
      • Jul 2009
      • 218
      Well when I lock from the door jamb it locks ALL doors..and Unlocks all door. Im not sure if the actuator is moving but its turning smoothly...Only when I unlock from trunk/passenger it doesnt unlock like its suppose to.
      • reelizmpro
        • 9558
        Probably just the actuator but I'd still clean the connector first.
        88 M3 - LACHSSILBER
        • r0meyrome
          • Jul 2009
          • 218
          I just went outside and tested everything. I feel like the drivers door is being locked/unlocked manually since I hear no motor going up or down... i will clean up the strikers but I heard that isnt really part of the central locking...
          • r0meyrome
            • Jul 2009
            • 218
            Problem fixed. Actuator was bad replaced with a used one from junkyard.
