USB/AUX-IN port
  • ethrtyiS
    • 8147
    ^You have your heater box to work on.
    「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
    「my feedback thread」
    • AbsorbantNut
      Non faccio funzionare questa merda
      • Jun 2010
      • 2491
      U can wire an aux input into the stock radio. I did it, all u have to do is dissassemble it and find the red/whire/black wires on the tape input & solder your connections there. Sounds much cleaner than a tape adapter/fm modulator
      '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
      • MattM
        • Apr 2009
        • 931
        ok guys, i spoiled myself for xmas and got a new one to play with. No it wont fit in the console spots, but now that i think about it i prefer it being down near the parking brake somewhere....
        Im going to make an adapter so it can plug into any normal deck that supports aux in/USB... basically just give it male usb and 3.5mm plugs on the back.
        i was thinking if this works i could do a group buy on the adapters.... if anyone is interested... more details when i actually get one done.
        Full Build Thread Here
        • lga714
          • 315
          I don't have the stock radio but I'm curious as to how it will turn it out. Let us know how it turns out in this thread.
          mtechII 5 lug S50
          • MattM
            • Apr 2009
            • 931
            this will work on any radio that has usb and/or aux in features on it!
            I was digging through my box o connectors and found one that works...
            but this one is proving difficult!, any ideas on part numbers?!?
            • freeride53
              • 11972
              I saw an E30 at the yard with one. Similar to the aftermarket alarm blanks with the led fitted to them, that are common on old e30s. Figure it cannot be hard to stick a jack and wire into that. This is the LED-blank I was referencing: (my car's old dash setup)
              1983 Peugeot 505 STI
              1992 Volvo 240 Wagon
              • MattM
                • Apr 2009
                • 931
                one cable made
                • PFCRayB
                  • Nov 2009
                  • 403
                  so how much would this be anyway?^^^^
                  Originally posted by Erick
                  Dude the M30 is stupid simple design. It's 6 manly men inside the block pushing up and down on the cylinder with Hercules-like force.
                  • CabrioPunk
                    • 1451
                    Do want.
                    • ethrtyiS
                      • 8147
                      oh very nice progress. more details por favor.
                      • joshuafr
                        • Jun 2010
                        • 143
                        I need to see a write up of this lol. Im assuming you have the stock H/U?
                        Is that Hitler having a Juicy Juice in your avatar?
                        Originally posted by Raxe
                        yes :(
                        Originally posted by Wh33lhop
                        I FUCKING LOVE JUICE. a
                        • MattM
                          • Apr 2009
                          • 931
                          I dont have the stock H/U, but could probably make a similar adapter for it.(i can easily source one)
                          My original i am making is mainly to have a clean look to any after-market radio, rather then having a USB port hanging out beside the cig lighter, and an aux cable in the glove box, this provides a clean OEM look and keeps those features.
                          I went today and dug through a massive box of E92 wiring, and had no luck finding the other connector......
                          • CabrioPunk
                            • 1451
                            This is exactly what I want for my vert. I have a spare rear ash tray I would like to fit a USB port and AUX in to. USB to power only. AUX to stock premium radio.
                            • MattM
                              • Apr 2009
                              • 931
                              At this point it looks like it would cost about $40 per adapter to have both USB and 3.5mm, or $20 per cable if you only want one or the other.
                              Solder-less adapter with all new oem pins and connector housings.
                              I just ordered all the parts to make one(not just the soldered prototype), so once that is done ill get some real pictures and gauge interest.
                              • Axxe
                                • Aug 2004
                                • 3355
                                Can you measure this? Looks like it will fit into an e36 perfectly, just want to confirm before I order.
                                Keep it slideways!!
