What size spacer would i need to fit a non-airbag steering wheel on an airbag car?
  • audiquattrot
    • May 2008
    • 3836
    Also is there any wiring that needs to be done or is everything else plug/play?
    TIA.
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
  • reelizmpro
    • 9559
    Apparently there is a factory part that works. Do a search for the part number. I just went to home depot and bought several washers that got the job done. You also need to jam the spring loaded locking mechanism for the airbag with a toothpick or something otherwise it'll keep you from turning the wheel. Then unplug the connector at the orange airbag box underneath to disable the SRS light. It's all a pain in the ass but well worth it as that airbag wheel is just plain.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Ian Bowers
      • Apr 2008
      • 1120
      Truth. You can get it from any E30 with a steering wheel, part # is 32311120260, you only need one.
      Just pull that pin out with pliers, or your fingers.
      And that as well, you'll be done!
      • reelizmpro
        • 9559
        Ian, if I remove that pin will I be able to reinstall it if I were to go back to the airbag wheel? it's dangerous if it were to ever dislodge and pop back out while driving.
        88 M3 - LACHSSILBER
        • Ian Bowers
          • Apr 2008
          • 1120
          I will go yank it off my parts car to check to see if it's able to be reinstalled.
          • Ian Bowers
            • Apr 2008
            • 1120
            Okay, yeah. Easily reversible. It's just a little push-pin with a spring on it. You press it back into the hole you pulled it out of, and it works just like it used to. I checked it on my car to be sure.
            pics showing the pin(and the spacer the OP will need, the car comes with the one in the picture on it, you need to stack an additional one after the steering wheel.):
            • audiquattrot
              • May 2008
              • 3836
              you guys are awesome! thanks so much!
              #snwmble
              Current:
              Past:
              • Danny
                • 14216
                I got the wahser, if you need it.
                • audiquattrot
                  • May 2008
                  • 3836
                  ^ PM sent
                  #snwmble
                  Current:
                  Past:
