Water pooling in trunk under jack?
  • BMWManiac
    • Dec 2010
    • 1091
    I keep getting some pooling underneath the jack.....it was half covered in water last time I checked. I pulled the piece out and didn't see anything that looked like the issue. Is there a drain there that could be clogged?
    1997 Artic Silver M3
    CES GT4094r 651hp/615tq @ 24 psi
  • StereoInstaller1
    GAS
    • 22679
    Tail light housings, antenna grommet, broken spot weld near hinge, leaky window, side window trim panel (rain gutter) mounting bushes leaking, LOTS of stuff can leak back there.
    GL!
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
    • Tricked 323i
      • 617
      GL!
      Luke
      Alex,
      Also check the Trunk seal.
      Kevin
      www.seatkit.com New Site first week of April 2011
      Your DIY upholstery source
      e30tech forum sponsor
      E46 uphosltery kits coming soon..........
      kchinn@creativeoptions.info
      • devon.818
        • Feb 2011
        • 2937
        i heard sunroof seal can cause it too?
        tap the taillights and look for moisture in them also.
        • BMWManiac
          • Dec 2010
          • 1091
          So, think I have some more maintenance to do....
          Trunk seal is fine, check.
          Antenna grommet crumbled in my hand....ordered
          Found water in the tail light housing.....seals ordered
          We'll see if this takes care of it
          • Holland
            • Nov 2008
            • 7212
            Check the side window trim like Luke advised too, the plastic can get old and brittle and that leaves holes directly into the trunk. To check the sunroof drain, open the sunroof and run water through the rear holes, check in the trunk for proper drainage. Tail light gaskets are a huge culprit as well.
            Originally posted by DEV0 E30
            • atle36m3
              • 427
              also take a look at the sunroof drain fittings that flush the water. the old gaskets go, i sealed mine with some black silicone.
              and of course all of the other things above...
              • StereoInstaller1
                GAS
                • 22679
                you re talking the ones around the trunk side vents?
                Closing SOON!
                • atle36m3
                  • 427
                  yep i found a bunch of water coming out around those
                  • Nick_S
                    • Apr 2011
                    • 3655
                    Mine is doing the same thing. Some good areas to watch for in here.
                    91 318is M50 swapped
                    05 Honda Pilot
                    24V swap thread
                    • StereoInstaller1
                      GAS
                      • 22679
                      The oddest one is the hinge mount spotweld. It is just outside of the trunk seal.
                      Closing SOON!
                      • Stevie30
                        • Apr 2007
                        • 1534
                        Originally posted by Tricked 323i
                        Alex,
                        Kevin
                        I found one recently where the trunk seal was in backward. The gap was up, next to the back window. Duh!
                        1991 325ic and 1991 318is
                        • Tricked 323i
                          • 617
                          Stevie,
                          I am jealous of all your AC's. I need to find some for my E30M......
                          Kevin
