Gutted my interior...halp please
  • freeride53
    • 11972
    I've taken all of my seats off, popped the ski-pass cut-out, and I'm trying to remove my carpet, but I'm not sure how to..How does one remove the door sills properly?
    My main goal is to replace my antenna cable, which is torn somewhere deep in ze dash. Anyone done this before?
    I had to go to safeway today, so I drove around the suburbs with only a lawn chair as my drivers seat.
    Thank you
    1983 Peugeot 505 STI
    1992 Volvo 240 Wagon
  • Jafxod
    • May 2011
    • 1301
    Everything just pops off
    • bmwstephen
      • 2463
      i thought early model cars had their carpet glued on
      • ethrtyiS
        • 8147
        use a flat head screw driver, and pop them off.
        「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
        「my feedback thread」
        • N2MYE30
          • Oct 2007
          • 5536
          The sills do pop off but be ready to buy some new ones as they like to break.
          COTM
          • freeride53
            • 11972
            Yes I have a late model (1991 four door 318i)
            I found that the carpet is glued on, and that foam shit all came apart :(
            • robrez
              • Jul 2008
              • 3376
              9, 10, and 12 pull straight up. Use a prying tool. For 11, there is a fastener at the back end, remove it, then slide it out toward the trunk. To remove the carpet, you only need to remove 9 and 11.
              January 2012 COTM
              • glucklich21
                • 1912
                The carpet isn't glued on, just sort of melted is the best way I can describe it.
                If you need that cable, I have a spare you can have, just pay shipping. ;)
                • Eecen
                  • Jun 2010
                  • 1235
                  Originally posted by robrez
                  On 9 and 11 pop up the end closer to the B-pillar (??middle of car) then slide the plastic trim piece out leaving the white clips inside the frame.
                  You're less likely to break the plastic clips, and trim if you do it like this.
                  • freeride53
                    • 11972
                    Haha, I got it off finally today, but then I actually cracked off and broke the sill itself Oh well, PNP can solve that.
                    But tell me what you guys think about this: Since the antenna cable goes so deep into the dash in the midst of the harness, I plan on running the new replacement cable with a shortcut under the steering column and over the bolster... good idea or am I too ghetto for thinking of it? :D
                    • ethrtyiS
                      • 8147
                      just tuck it away nicely. take the cluster out and run it over steering column.
