So today I walk out to my car this morning and the drivers side floor is soaked No windows were down seat wasn't wet neither was the dash or door panels and it's only on the drivers side floor too don't know what to do or where it's coming from its a 90 325i sedan with sunroof if that helps has anyone has this problem?!
Wet carpet need help :/
if not coolant check the elephant grommet in the engine bay...sigpic
Levent
%20levent@gutenparts.com
Ladies:
Originally posted by e3027sedan View Posthmm no not sure but why would it be coolant ill go smell it lol
and isnt the elephant on the passenger side?
as mentioned - check for coolant. heater tap or core are quite common to leak after age.sigpic
Originally posted by e3027sedan View PostBut wouldn't if it's heater it would be coolant and my coolant is green?!
Originally posted by StereoInstaller1 View Postand you are certain it is not coolant?
Trust me, a leaky heater core is easier.
Leaky heater core is fun too. I had one blow on me. It was about 20 degrees out, too. All of the 180 degree coolant dumped directly onto my right foot...as I was doing 35 or so in heavy city traffic...the windows instantly went solid steam, as in opaque.
That particular failure really sucked ass.
wow thats soo shitty and yes 100% its not green and i dont think i have an elephant on my car took it off to clean during the motor swap and never put it back on so not too sure what it would be and not looking forward to tearing the dash out if i do that ill take the heater out completley and wire in an electric one you put in your bedroom lol
Is your parking space level? You may wanna check your sunroof drains first.
Basically, you pull the dash, then pull the heater box and replace the gasket with top-quality foam weatherstripping.
That is a good time to pressure wash your carpet too...but then you get to let it dry.
Bummer, man...maybe check your windshield for leaks too?
Thread jack along the lines
Whenever it rains, my rear passenger foot rest area gets wet. Someone mentioned a gromet from underneath may be worn but I doubt it because it only happens when it rains and any other time I've gonne over deep bodies of water, nothing gets wet, so what gives?
Good luck OP, hope Luke's help fixes your issues.@IRON-E30 aka Edwin:D
