Quick quesion for a 318is steering wheel hub
  • asubimmer
    • 6482
    I have a 91' 318is and the momo steering wheel hub (2006) says its for a 318i not the is and it does not include 91'. Momo does sell a diff hub (2008 ) for a 91'-98' 318i but says nothing about a is. Would the 2008 hub work for me? What hub do you 318is people use w/ your aftermarket wheels? I am getting a 350mm momo wheel if that matters any.
    edit: this is the apps for the 2008 hub:
    BMW 318I 1991-98
    BMW 318IC 1991-92
    BMW 318IC 1994-97
    BMW 325I 1991-95
    BMW 325IC 1991-92
    BMW 325IS 1991-95
    BMW 325IX 1991
    BMW 328I 1996-98
    BMW 328IC 1996-99
    BMW 328IS 1996-99
    BMW 850I 1991-92
  • asubimmer
    • 6482
    bump
    • Digitalwave
      is a poseur
      • 6300
      You want the 2006.
      RISING EDGE
      • asubimmer
        • 6482
        are you sure about the 2006 cause it says that it does not work on cars w/ airbags. does the 2008 fit a 91' 318is?
        • AndrewBird
          The Mad Scientist
          • 11898
          I would think that the hub would be the same for airbag and non-airbag cars as you can fit a BMW non-airbag wheel on a car with an airbag. The only thing I can see that might be an issue is clearance around the hub.
          • Digitalwave
            is a poseur
            • 6300
            I am sure. I have fit one on my car. The 2008 is for E36's.
            RISING EDGE
            • asubimmer
              • 6482
              did the 90' 325i's come w/ airbags?!?! maybe i should just call momo and see what they say.
              • Digitalwave
                is a poseur
                • 6300
                Oh my god... just listen to me. My car had an airbag. The splines on the steering column are the same on all E30's. I have an M-tech I from a 325iS non-airbag in my car right now.
                The 2008 is for E36's and will not fit E30's, the splines are different.
                RISING EDGE
                  • 37833
                  Here, how about this, my car is a 91 and I have the 2006 hub on it, no problem.
                  If you buy the 2008 all you will end up with is a hub doesn't fit
                  Trust us
                  Grover Beach, California
                  BimmerHeads.com
                  • asubimmer
                    • 6482
                    i trust you mr 325. Thanks for the help. I just wanted to be sure cause i don't want a wrong part that does not fit.
