need help repairing seat mechanisms
  • camip
    • Nov 2011
    • 1253
    This is to the lever in front of the backrest lever. The gear looking thing won't move unless I force it how do I fix this.
  • jeffnhiscars
    • Jun 2011
    • 6011
    Not 100% sure what the challenge is, but assuming you are releasing that gear catch and its just binding, I use carb cleaner to get the junk out then some light lubricant. Note..do not get carb cleaner on your seat fabric\leather.
    Bottom line is its likely just gummed up.
    Alice the Time Capsule
    • camip
      • Nov 2011
      • 1253
      I cleaned it pretty well and just wouldn't move unless I used a flat head screw driver. Caught my hand multiple times got pissed and gave up I will try the carb cleaner if I pull the seats out again.
      • Ceeker
        • Sep 2009
        • 2821
        I haven't run into that problem..sounds like it's just stiff from non use. Penetrating lube and work the mech to free it up. see if that helps. Otherwise....replace the seat frame bottom.
