Going to flock the dash.
Well... Got it done. Came out pretty good. It's not perfect, and I highly recommend having two people apply the flock. Also an air-gun will blow through the 3oz kit in about 10 seconds. Be sure to invest in the 16oz bag.
And without further ado... Here are pics.
Cut "V" into the cracks so the epoxy can get down in there.
So Brittle!
Plastic Epoxy time!
Forgot to take pics of us sanding down the epoxy. It was rough... I highly recommend using a dremel to power through it.
Time for Bondo!!
Cobbled together a little plastic blast cabinet in order to catch all the excess flock fibers.
FLOCKED!!!!
I did not have time to take any pics of me laying the adhesive. You only have about 10-15 minutes before it not tacky enough... and I was brushing it on like a mad man.
Spraying the flock was... not easy either. Like I had to refill the spray can with flock about 4 or 5 times. And I am racing to get it all sprayed on before the glue firmed up on me. I think it came out OK. Its not perfect and you can see in a few spots where the flock is not as thick as I would have liked. However... It looks about a thousand times better than it did being all faded and cracked to shit.
Hope this helps others accomplish as well. I will post pics with it re-installed eventually. Also I plan on flocking the glove box (minus the latch).Comment
Is that charcoal or black?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
Looks good man! Actually looks better than mine turned out honestly, even after re-doing mine I still have small patches that aren't fully coated. All in all, the flocked dash definitely looks better than a cracked one but in my case I'm still planning to replace it with a crack free one eventually.Comment
are you planing on doing anything else in flock as well? the console or the a pillars/sunroof(check light) panel?
i am planning on re-doing anything that had the same looking grain in my interior so that its uniform, and flocking is on my short list.
thanks1985 325e - a cheap work in progress
http://myquest4happiness.blogspot.com/Comment
I think im going to do the glove box, and the rear shelf. I saw a 5 series headliner that was flocked, and that looked amazing. So I might do that as well, but I really just want to get the "lower" interior buttoned up before I start dicking with a perfectly fine tan headliner.
I just got paid, so I should have a few bucks in the budget to buy some carpet dye and what not so I can continue on with this.Comment
Great job! I did this to the dash in my old 02. The only sufferance being I painted it with bed liner before flocking it.
My recommendation for others trying this is to use a small foam roller to put down the glue. It will be more even and will take less time.sigpic
DREWLIENTE
