Dash Swap!
  • 318kid
    • 337
    Dash Swap!
    What does one all replace during a dash swap?
    I know the A/C Heater vents should be replaced or fixed (so they don't drop down after every bump!) But what else should be done? I know the swap takes quite some time, so I want to try and limit the amount of times I have to go back in there by knocking out a lot of the things at the same time.
    Thanks, Preston
  • 318_i
    • Mar 2012
    • 65
    I'm in the same boat. Think I'm just gonna tear it apart and see what I come up with
    • vpilarrt
      • Jun 2006
      • 2096
      An easy way to fix the vents is to put a small o-ring over the pivot pin on one side.
      • drumad
        • Aug 2009
        • 1700
        so you're saying cut an o-ring and slip it around the pin?
        genius
        2008 335i - n54b30
        1991 318i - m52b28
        1994 fzj80 - LAND CRUSHER
        • jrobie79
          • Mar 2006
          • 2526
          or put the fuzzy side of a piece of velcro against one of the sides, it should tighten up the gap and make the vent hold its position
          1991 318i ---- 308K - retired
          • 318kid
            • 337
            Those are both great ideas. Anything else I should do while I'm in there though?
              • 34844
              Heater core? Its probably easier without the dash in the way.
              • OnMy2ndE30
                • Sep 2011
                • 385
                Hey bro. Funny thing, My name is Preston as well, lol. Small world. Some things I plan on doing while I do mine is to swap the expansion valve for the a/c (you have to pull the dash if it ever goes out) and replace the foam seal for the blower box (where the dash vent tube meets the blower box right on top when the dash is out) I am sure I am missing some things here.
