Steering Wheel Removal
  • anthonymax007
    • 174
    Originally posted by D-rock
    Really? I have no idea what it could be then? Its a 20 second job :/
    Getting the airbag wheel off was quick, easy, and painless. This Mtech-1 has been a pain in my ass. Its old and worn, I put it on more to see how it would feel compared to the airbag wheel....and now it won't come off lol.
    fried chicken
    • jaywood
      • Jul 2010
      • 4528
      Did you accidentally weld it on?
      • themoonman
        • Aug 2011
        • 196
        i hate when that happens.
        what year is your car? was it factory airbag or someone just put the wheel on?
        • anthonymax007
          • 174
          It's a 91' 318is. Originally an airbag wheel which I took off easily. I was test fitting an MTech-1, and now its stuck.
          LOL no. Welding is not my forte.
          It's drivable, so I can still get around even though this is my DD. I can feel/hear the wheel rubbing against the steering column when I turn.
          fried chicken
          • Freude am Fahren
            • Aug 2011
            • 1190
            Does the wheel budge at all when you yank at it? Are you grabbing the wheel on two opposite ends and pulling straight out? Use a mallet instead of a hammer, to minimize damage, and hit the wheel all around while yanking the wheel by hand on the opposite end (maybe borrow a set of hands from your neighbor or something). If that didn't work try banging on it towards the column as if you are trying to install it as opposed to removing it. Something is locked in there and you need some movement to get it dislodged. I feel for your headache brother.
            Life is too short to be driving a Honda.
            • anthonymax007
              • 174
              I can feel it moving, but barely. I'm going to try using a rubber mallet tonight. At first I thought the steering wheel lock wasn't disengaging, but then I wouldn't be able to turn the wheel at all (which I can do).
              fried chicken
              • aclark
                • Apr 2011
                • 87
                Any solution to this?
                I'm having the exact same problem on a '91.
                And no it's not the wheel lock
                • LagunaVert
                  • 255
                  Maybe if you put a notched plate between the wheel and the column you could use a 2 jaw puller to force it off. You might end up damaging something though.
                  TWELVE HAMMERS
                  • jan318
                    • Mar 2012
                    • 16
                    • ELVA164
                      • 4861
                      Is it possible that the end of the splines on the steering wheel have bitten into the steering column where it widens out? That's what comes to mind for me. It would take some force to get it stuck there I would think, but I bet that would bite pretty good if it happened.
                      • grays
                        • 1343
                        use a puller
                        • kewliost
                          • Aug 2012
                          • 16
                          leave the nut on the thread when your trying to bash it off...
                          • mcskibadee1
                            • Feb 2012
                            • 1379
                            same problem here with a momo monte carlo wheel.
                            TRANSACTION FEEDBACK HERE
                            FOR SALE ITEMS HERE
                            • IRON-E
                              • 16548
                              The wheel was not aligned properly, hence it bit the splines incorrectly an now stuck.
                              Time for the blow torch and a new steering column. :D
                              @IRON-E30 aka Edwin:D
                              • mcskibadee1
                                • Feb 2012
                                • 1379
                                Still have this problem, I can pull it out like 1/4 inch and thats it. It is definitely hitting something because you can hear it. I have a 1991 318is, any ideas?
                                FOR SALE ITEMS HERE
