E30 seat repair - seat recline
  • kumulonimbus
    • May 2012
    • 178
    The drivers' seat that I picked up had a recline issue where when you pull the lever up to recline and then push the lever back to neutral, the seat back doesn't lock. I'd have to fiddle with the lever a bit to get it to lock again.
    Not sure how common of an issue this is but my friends' sports also have the same issue, so decided to document the super simple fix in case it's useful to someone down the road.
    These steps were done on comfort seats but should be exactly the same for sport seats.
    With the help of these three tutorials, I took apart my seats. You DO NOT need to do this if you are only interested in this particular fix. You only need to take off the plastic mechanism covers (1 on each side).
    There is a metal thing with teeth that moves when the seat reclines.
    Look into where the arrow points
    ... and you'll see this:
    The metal things beside the teeth (see arrows above) move out of the way to allow the seat to recline and then catch the teeth to lock the seat back into place. These metal pieces weren't moving nicely, so a little WD-40 in there did the trick. Do this on both sides of each seat.
    Simple fix, and saves you the embarrassment of your seat back falling on your rear passenger.
    1990 BMW 325i Coupe
  • jeffnhiscars
    • Jun 2011
    • 6010
    Whats Ive also found is that the posts that spring connects to get gummed up and the spring doesnt seem strong enough to fight the extra resistance. A few minutes with some brake cleaner seems to really help.
    Alice the Time Capsule
    • TrentW
      • 2815
      Trying to do this now and removed the retaining screw on the round plastic hinge cover, but it still doesn't want to come off. What's the dealio?
      • Semblance
        • Jan 2011
        • 433
        The plastic hinge cover has a small lip on the lower rear, you have to pry it over the mechanism.
        '89 lachssilber vert - Frau Blücher
        '84 alpine 2dr - gone to the great beyond...
        '00 titanium 4dr e46 - bricked
        • TrentW
          • 2815
          That's not it--something behind the cover above where the slotted head plastic retainer came off. I know it sounds simple, but the bugger won't move. Will be back on it later today...
          • Semblance
            • Jan 2011
            • 433
            There's a second threaded post immediately above the one that the plastic nut screws on to. There's no nut for it, it's friction fit into a receiver in the cover, just wiggle.
            • Steven
              • Dec 2012
              • 2305
              When i redid my sports seats I cleaned the mechanism with some strong cleaner (like what they use in a parts washer) then lubricated the whole thing, and along with that and new rear shocks the seats recline and everything like brand new!
              Feedback!
              Custom Cup Holder Consoles!
              Calypso Story--S50/Shaved and Tucked Bay
              • thor:it
                • Jun 2012
                • 9
                Thanks
                Driver's seat just needed this, thanks!
                Ian T.
                BMWCCA #518713
                1990 325is | 2001 325xi Touring
                • jeffnhiscars
                  • Jun 2011
                  • 6010
                  Don't ignore the seat shocks ;)
                  • TakiM3
                    • Oct 2016
                    • 24
                    Great tip, worked like a charm! I thought I had stripped the gear mechanism initially!
                    • Drei Zwanzig
                      • Nov 2016
                      • 11
                      Super tip! My "new" sport seats are like this. This will help a lot. I also think I have to bite the bullet and buy new shocks... Thx mate!
                      • EthirtyIS
                        • Feb 2011
                        • 270
                        Brake clean or solvent with some air pressure helps get the 30 years of crud out in a hurry. I use triflo to lube up the gears and bushings, WD40 will work but it's not much of a lubricant.
                        OP, Nice job on the write up, now on to the sliders, those are fun to clean out.... ������
                        Proud Owner and Operator.
                        • honda.lioness
                          • Oct 2017
                          • 11
                          kumolonimbus, great thread. My 1988 e30 seat would not recline. I shot PB Blaster in the location the red arrows show in your first post. This fixed it right up. I am now lubing and cleaning a bit more before re-installing. Thank you!
                          • m5james
                            • Feb 2012
                            • 59
                            Dumb question time but you pull the recline handle on my seat and it'll just fall backwards, there's no issue with it retaining position so long as I don't let go, it's more that there's maybe a return spring that is missing or broken. Suggestions before I take the seat out/apart?
                            • rcarradine
                              • Sep 2012
                              • 31
                              It sounds like you need a new seat shock to resist gravity pulling it down.
