mtech II replacing airbag steering wheel
  • 330andru
    • 8
    Hello
    can anyone fill me in on the conversion of a 90 ix w/airbag to a
    mtech II wheel .
    I took the wheel off placed the mtech on ...
    then the gap of about .750 of an inch is between the steering post
    plastic and the back of the steering wheel, also the wiper and signal
    lever are too close . Do I need a spacer and what can cover up the gap.
    thanks
  • audiquattrot
    • May 2008
    • 3836
    I put an Mtech 1 on my 90 ix, and used this spacer. The only drawback to the swap, is the turn signals/wiper arms will sit close to the wheel. Also i disconnected any/every SRS plug associated w/ the SRS....to get rid of the light. I believe they were all orange plugs if memory serves me right.
    http://www.ecstuning.com/Search/32311120260/ES52979/
    www.instagram.com/snwmble
    #snwmble
    Current:
    '05 BMW M3 - Silver Grey/Imola Red
    '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
    '15 Mini Countryman - Blazing Red/Carbon Black
    Past:
    '01 Audi Allroad - Light Silver/Platinum Saber Black
    '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
    '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
    '90 BMW 325i - Schwarz/Tan sport *Sold*
    '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
    • audiquattrot
      • May 2008
      • 3836
      #snwmble
      Current:
      Past:
      • audiquattrot
        • May 2008
        • 3836
        btw u can't really use a spacer to gap the distance between the steering wheel itself and the signal stalks, or else your horn won't work and your steering wheel won't lock.
        #snwmble
        Current:
        Past:
        • reelizmpro
          • 9546
          Bend the stalks.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
          • 330andru
            • 8
            thanks for the info, and the e30tech thread that explains more
            I'll check real oem on parts available and see if the stalks can be changed.
            or may have to resort to plan "B" bend the stalks
            thanks Guys big help
            • lbreevesii
              • Aug 2009
              • 412
              user spacer, bend stalks, or switch to non-airbag stalks.
              I don't always wreck cars, but when I do I wreck them into trees.
              91' 318is S50 swap - The Black Widow
              • SeatownE30
                • 594
                Can you bend the stalks while on the steering column or do you need to remove them for better access/leverage?
                1991 318i Sedan
                2005 X5 3.0i Sport
                2010 328i M-Sport Touring
                • reelizmpro
                  • 9546
                  I bent mine in 5 minutes while on the car. Take a pair of channel lock pliers, wrap the teeth with a shop towel so they don't gouge the stalks and find the area of the stock where they are already bent and bend them more. It doesn't take much to gain the clearance needed.
                  88 M3 - LACHSSILBER
                  • SeatownE30
                    • 594
                    Awesome! Thank you
                    1991 318i Sedan
                    2005 X5 3.0i Sport
