How did you guys install your shift boots?
  • JonnyOg
    • Sep 2012
    • 191
    Hey just curious how you guys installed your aftermarket shift boots and ebrake boots. I used hot glue for mine and I'm not really happy with it.
  • Cletonius
    • 2809
    Contact cement. You can use regular rubber cement but it will degrade over time. Not a big deal on a shift boot as the bezel keeps it in place, but to be correct and have a long lasting bond, you need something that's able to handle high heat. Most trim shops use DAP Weldwood HHR.
    With rubber cement you want to paint the frame, apply the boot, and clamp it while wet. If you're using the Weldwood HHR you can paint each half and let it dry, then stick them together for an instant permanent bond.
    Alternatively, you can ship your stuff to me and I'll mount them up for you on the cheap.
    - Josh
    1990 325is
    Need a shift boot?
    Looking to buy shift boot frames, PM if you have one to sell
    Here's what happens when you let the internet pick your license plate
    • JonnyOg
      • Sep 2012
      • 191
      Ah good stuff thanks man I'll definitely do that.
      • Spyke
        • Sep 2012
        • 494
        I did exactly what Josh advised, although I reinforced with some gel super glue at the corners just in case.
        Current_SeeDee 1972 e10 Luna 1975 e10
        Past___Veronica 1994 e36 Le-Ah 1987 e30
        • lambo
          Captain Scene Points
          • 10953
          I just used a hot glue gun and it's been holding for a year and a half now...
