Definitive bulbs and quantity to overhaul gauge cluster?
  • 5mall5nail5
    • 156
    Doing some work on our E30 and I noticed the speedo is out. God knows what else is out. Can anyone tell me what PN# I need and what quantity to replace the bulbs as a whole?
    Thanks!
  • jrobie79
    • Mar 2006
    • 2526
    bump
    1991 318i ---- 308K - retired
    • jeffnhiscars
      • Jun 2011
      • 6010
      Richardodn on BF has posted that list often
      Alice the Time Capsule
      • rhE-30
        • 498
        x3, post that list here, dont know Richard, or browse BF.
        • jeffnhiscars
          • Jun 2011
          • 6010
          maybe you should start browsing bimmerforums...if you need bulbs
          x3
          • rhE-30
            • 498
            The cluster diagram only shows two bulbs. 23 is a 12v 3watt & 24 is 1.2 watts.
            23 looks like this. 12volt 3watt. part #07 11 9 905 358 on bimmerspecialist. Real OEM says you need 3.
            24 looks like this. 1.2 watt. Part # 62 11 1 368 299. Real OEM has a question mark in the quantity box.
            This one is also is number 24 on realOEM. 2Watts. Quantity is listed at 2, part # 62111375774. Looks like this.
            If I am mistaken let me know.
            • kmarei
              • Apr 2008
              • 194
              You need 24 for every warning bulb you have
              So 2 for turn signals
              1 for high beam
              One for hand brake etc
              I also used the w5w in amber instead of the w3w
              You only need 2, not 3
              Buti removed the 2 amber plastic cups that fit over them
              Much brighter, and less issues with heat
