Ferrari gate shifter?
  • kalib0y
    • Dec 2004
    • 3620
    found this. I think Hamann or Racing dynamics made them before
    95 7.1L 16V E36 M3
    Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
    LIKE my Facebook Page! CLICK HERE
    • Simon S
      • Oct 2004
      • 3758
      want..
      -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
      • Simon S
        • Oct 2004
        • 3758
        good to know about the reverse bang.. I wonder if the console over can be adjusted over.
        and maybe there's adjustment available to the rear mount?
        (all trans and engine mounts are fresh as well)
        • lumbergh17
          • Dec 2009
          • 74
          The AKG doesn't hit, and if you were to make a shift gate for it at the stock console height, like I said it wouldn't work. It'd have to be basically an oval shape. The throw is so short.
          Might be able to do it though with a stock setup but it might be a pain if you don't get it just right and it binds or hits. Cardboard template would be a cheap test solution.
          1988 E30 M50 Turbo
          586whp 523wtq
          • J.Rizo
            • Aug 2012
            • 949
            what makes a DTM shifter so? does it not pivot like regular shifters? idk see why he cant just make the plate and swap it for the shift boot. but thats because i dont get this. can someone explain? not a spoon fed meal, just curious.
            @joshua.j.rizo
            Originally posted by SpasticDwarf
            Just remember next time you hear "late night when you need my love" I'm gonna be sitting somewhere way more bitchin' than you, driving or not.
            BUY MY BUGATTI WHEELS:
            http://www.r3vlimited.com/board/showthread.php?t=377693
            WRITEUP TO MY RHD SWAP:
            http://www.r3vlimited.com/board/showthread.php?t=371904
            • Simon S
              • Oct 2004
              • 3758
              The DTM shifter gets hard-mounted to the top of the transmission tunnel.
              This is great in terms of anti-slop since all stock shift "carrier" hardware is eliminated. It's the carrier hardware that wears and gets so sloppy over time.
              In terms of your question, the pivot point is raised "upward" from stock with the DTM to the top of the transmission tunnel. That pivot point brings it very close to the console. Because of the shorter distance, the gear lever arm essentially doesn't "travel much" through the plane of where the console is. Hence, it doesn't move enough to cause a discernible pattern via which a "gate shifter plate" could be used.
              • J.Rizo
                • Aug 2012
                • 949
                thanks. this was a perfect explanation.
                sucks that it wouldn't work out. I'd love to have one because of the patterns you'd be able to out on it.
                @joshua.j.rizo
