Loose Sport Seat Front Rail Bearing
  • e30Chris
    • Nov 2012
    • 68
    Originally posted by jeffnhiscars
    Im surrounded by seats and seat frames and am having trouble seeing a) how that part can wear out since it only gets wear when you tilt the seat back for rear seat access and b) if it did get worn that it would cause a noticeable problem.
    Typically they are stuck tight and have to be coaxed out rather than being loose so I am curious to see if this solves your problem
    Interesting. My seat is definitely worn out here, it rocks back in forth on acceleration and braking at this point. I can even hold that point with my hand and feel the seat move off the seat base. I've also taken the seat out to verify that the piece is in fact worn out. If it matters, these are in my 1991 318is.
    It does appear to be a load-bearing part of the seat, as in, once it's off and the rear disconnected, the seat comes off the base. I get that the most wear would occur when the seat is being tilted forward or back, but somehow mine's worn. I bought the car from the original owner in November who was a small 87-year old German guy. Unless he was constantly folding the seat forward and back over 20-years, I'm stumped as to how it wore out. We'll see if the new bearing tightens things up there. I'd love to have the seat stop rocking.
    • Swanny
      • Mar 2012
      • 2834
      So its safe to say the mounting points are sturdy and its just this bearing thats worn? Ive had a seat mounting bolt rip out of the floor after it was moving like you described. Unlikely the same issue but wanted to give you a heads up.
      Swanny!
      SUCKERS.
      • e30Chris
        • Nov 2012
        • 68
        Yea, thanks for the heads up, but I double checked all the mounting points hoping they were the cause. They're all tight. I can actually feel with my hand the seat rocking at the bearing point on acceleration and braking.
        • Sean
          • 5793
          Digging up this old thread. Did the pieces from the comfort seats fix this wobble?
          - Sean Hayes
          • noid
            • 1535
            Bolt and nut are the solution.
            Some folding sport seats develop a noticeable back-and-forth rocking motion over time. This is primarily caused by wear in the rotating mounting lever, which creates clearance in the seat rail mounting arms. The resulting play is actually as much diagonal as it is forward and backward. While the user perceives it as a back-and-forth motion,
            Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
            Your resource to tools and tips: www.rtstools.com
