Anti-Lock Abs Light
  • Zinno_e30
    • Jul 2010
    • 553
    Anti-Lock Abs Light
    How do I remove the ABS light bulb? I do not want to pay $100 for the relay and would rather just pull the bulb. The brake lining light will be addressed with new brake bad sensors and a new SI board will be going in as well to take care of the oil service/inspection light that wont clear.
    Back of cluster for reference:
    Said lights:
  • kmarei
    • Apr 2008
    • 194
    You mean the brake lining bulb correct?
    The abs bulb is different than the other bulbs
    The other bulbs are mounted to a plastic base
    The abs bulb is attached to 2 wires that fits into the socket
    To remove the brake lining light
    Just twist the base that has an exclamation mark inside a circle pictured in the lower right hand corner of your top picture
    Twist it 90 degrees and it comes out
    • jeffnhiscars
      • Jun 2011
      • 6011
      You may find that the brake lining light is not the result of bad sensors as there are other causes. As for replacing the SI board chances are its just the batteries which can be bought for $20 and soldered in.
      Alice the Time Capsule
