Mounting Check Pannel
  • McGyver
    • 4634
    I had removed the check pannel from both my vert and coupe when I replaced interior trim and now they both fall out on every bump. It looked like the pannel was glued in on the vert and had a small metal plate bracing it, but nothing like that on the coupe.
    How are they supposed to be secured to the trim?
  • bmw325csi
    • May 2007
    • 4045
    They clip in. Once you remove them however, the cardboard on the trim gets all messed up and doesn't want to hold them in like it used to. I always use some clear silicone because its easy to remove later for service.
    harry/harout
    • McGyver
      • 4634
      i figured that they would just be wedged in there and that the cardboard was shot, so i'm just going to use some epoxy i have laying around the house. the appeal of pushing it back up every 15 seconds has been gone for months now.
      • bmw325csi
        • May 2007
        • 4045
        Just don't use any hardcore glue incase you want to remove it later.
        harry/harout
        • McGyver
          • 4634
          :/ well i guess that its a good idea to not go overboard on it....
          not as much fun though.
