Motometer/VDO: are they interchangeable?
  • Pipes
    • Aug 2012
    • 485
    Removed my wheel, removed/disassembled my Motometer cluster, replaced ODO gears, deleted inspection light bar, replaced all the old bulbs, reassembled, polished plastic to perfect clarity.... then dropped the whole thing on the floor. AAARGH!!! :letitout:
    Plastic face is cracked, tabs are broken off. So I need a new cluster, or at least the case and I can swap over my instruments. Anyone know if VDO and Motometer clusters are interchangeable if I find a VDO? Or if a motometer speedo will fit in a VDO cluster?
    1991 349is (wadded up)
    1984 Rabbit 2.0L16v swap (wife's)
    2003 LR Disco II (wife's)
    1993 MB 400SEL (son 1's)
    1980 MB 450SEL (son 2's)
    2004 KTM 525 EXC-R SM Sold:(
  • Cletonius
    • 2809
    I haven't put clusters side by side, but I remember the housings looking the same
    - Josh
    1990 325is
    Need a shift boot?
    Looking to buy shift boot frames, PM if you have one to sell
    Here's what happens when you let the internet pick your license plate
    • Pipes
      • Aug 2012
      • 485
      Anyone know if the plugs are the same? What about the way instruments screw in: are all of the connections located in the same places?
      • xtos
        • 81
        Motometer and VDO speedos have exactly the same pins,screws so they are interchangable.As for cases-No they are not all the same. Late models have a cluster plug. Thus a different board with service lights etc. Others do not have a plug...and lens part doesn't mate with back part.
        1990 318is M-technik2
