center console repair
  • randomtask37
    • 3154
    so i picked up a damn near perfect 2 button hole center console out of an early model 318 at the junk yard today. Ive been looking for one with just 2 holes for a long time. (doesnt have the window lock slot). It was pretty faded/dirty but some armor all wipes has this thing cleaned up nice.
    the ONLY fault is a dime size bubble in the tray forward the ash tray.
    anyone have any advice to fix a bubble like this? i know its minor, but im picky.
    98 M3/4/5
  • AndrewBird
    The Mad Scientist
    • 11898
    You could try a heat gun to help "relax" the material. Bubble like that are caused by the material shrinking with age and pulling up. You will likely never get it perfect though.
    • kmarei
      • Apr 2008
      • 194
      How about getting and injection and putting glue in it
      Not super glue, but some kind of upholstery glue
      And sticking the needle between the vinyl and the cardboard and injecting a small amount of glue right underneath the bubble
      And try to release a little glue as you pull the needle put so you can flatten the area the injection was in
      Then Apply pressure to the area to remove the bubble and the line where the injection went in from.
      I'd start with applying heat, to soften the area
      Then put pressure on the bubble
      Hoping it retains its shape when it cools
      • Northern
        I like cupcakes & sh!tboxes
        • 5283
        get a syringe, inject with adhesive, push the adhesive around inside the bubble until you can't feel any globs left, wipe the surface, and hold it down until the adhesive cures.
        Don't inject a lot or else it will be wavy/bubbly after from globs of the adhesive sitting there
        Originally posted by priapism
        Originally posted by shameson
        • randomtask37
          • 3154
          thanks for the advice. i was thinking about some kind of syringe technique. i think ill try heat + syringe of glue.
          98 M3/4/5
