I'm getting an analog clock to install in place of my deluxe OBC, so I need to know what's involved/need to install it and have it work properly. Thanks.
what's needed to install an analog clock?
Harness from one with an analog clock. OR the harness from a 2button OBC car. Just the harness that hooks to it, not an entire harness for the car lol
WillRIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
Welcome e30 (brilliantrot '90 325is) 12/23/06
DaveCN = Old Man
My signature picture was taken by ME! Not by anyone else!
Originally posted by george gravesIf people keep quoting me in their sig, I'm going to burn this motherfucker down. -
Spliced in as far as I know. I was originally going to do that from a 6button but decided against it cus I like knowing what the temperature is. So all the info I know is from what I have read.
DaveCN = Old Man
Originally posted by george gravesIf people keep quoting me in their sig, I'm going to burn this motherfucker down.Comment
Originally posted by PeaveyBassistSpliced in as far as I know. I was originally going to do that from a 6button but decided against it cus I like knowing what the temperature is. So all the info I know is from what I have read.
WillComment
Originally posted by kencopperwheatYou can use a power mirror harness too.HDE30 <3Comment
If you do a search, you will find a few threads on this topic (one not even a month old).
You just need to splice the 4 wire connector into the harness of your OBC. There are markings on the back of the clock identifying each of the 4 wires. The markings are as follows:
30 ----- power
31 ----- ground
58k ---- power for light
31g ---- ground for light
you can figure out which wire goes where if you look at the wiring diagram in the bentley manual.
Hope that helps.
-ErikComment
I have an additional question about the analog clock.
When wiring power/ground to the clock itself (not the light, It's the plug labeled "30"), When you turn the car off, will it keep the time? I dont understand what happens when you cut the power to it. I would think that it loses the time....On the other hand, i dont want it to drain the battery if it constantly needs 12V to it. It's kinda like a catch 22. Sooo which power would you hook it up to.Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholicComment
Originally posted by M3fan4evaI have an additional question about the analog clock.
GusComment
watches run for years on those tiny little batteries, I wouldn't think you should worry about the clock draining your battery too much.
"One of my top five favorite, like, cool...nerd cars"
'89 325i-sold
'98 528iComment
