M3 rear seats
    M3 rear seats
    I am trying to put my car an a bit of a diet and im starting with the interior. I am wanting to know if the M3 rear seats are lighter than standard E30 seats and if so will they fit in a standard E30?
    Float like a cadillac sting like a Bimmer!:)
    no and yes
    harry/harout
      Originally posted by bmw325csi View Post
      no and yes
      so the rear seats are not lighter but will fit?
        exactly. there is a little difference between 2/4 door e30 seat bottoms but they are interchangeable
        harry/harout
          Is there anything you can recommend to lighten my interior apart from just removing it?
            Remove all the sound deadening in the trunk and where ever else you might find it. What model e30 do u have?
            harry/harout
              I have a 86 325eta i am doing a lot of work to it soon invluding a 24v swap. I just want to make it lighter wile still being derivable and not annoying.
                Any amount of lightening you do to the interior will not be noticeable. Trunk tar is probably worth it, but otherwise, it's pointless.
                  1. Open trunk
                  2. Remove dead hookers
                  3. Clean stains
                  4. ????
                  5. Profit
                  1991 318is - Sold
                  1986 325 - Sold
                  Instagram - Lamoursum
                    this^ if it id going to be your dd there is no point in trying to make your car lighter. taking out all of the tar you might lose 100 or so lbs but not enough to feel a difference
                      Sport seats are around 45lb a piece, so if you never have a passenger its worth removing. The only heavy item left would be your carpet and that is certainly not worth the discomfort of removing.
                        Install 318 interior carpet (15-20lbs)
                        Remove trunk tar (45 lbs)
                        Install fixed bucket seats (50lbs)
                        Run a mazda miata or motorcycle battery (15-30lbs)
                        You could also take a cloth back seat and give it a quick once over with fiberglass resin. Cut away the now hard fabric from the frame and cushions and make some aluminum mounting bracket. For best results and an additional coat and sand down and give it a smooth finish. Then give it a couple coats of vinyl dye or get some fabric to match your race seats and install with adhesive spray.
                        www.gecoils.com
                          318 carpet is lighter than 325 carpet??
                            yes^
                            to the original poster
                            • you can remove the carpet,
                            • remove the sound deadening to drop some weight
                            • then reinstall the carpet.
                            my current setup
                            2008 Sparco Evo smaller size
                            Sparo Side mount
                            Wedge Engineering seat slider bracket.
                            no carpet
                            no sound deadening
                            no rear seats
                            no rear parcel shelf
                            no rear speakers
                            no trunk tar
                            Project
                            Parts for Sale
                            Feedback
                            YouTube Channel
                              gut the back seat and leave anough foam so it keeps its structure haha
