Will an early model sunroof fit in a late model??
  • EThirty318i
    • Dec 2010
    • 219
    I have a '84 318i shell with the manual crank sunroof, and a '91 318is that had a power sunroof but it was not in the car when I bought it.
    My question is, if I took the '84 sunroof components out, would they work in the '91??
    I've looked around and haven't really found anything regarding this.
    Thanks in advance for any info!
  • reelizmpro
    • 9543
    Just the sunroof panel? yes, you can. To be sure, just look at the mounting points. It should all be the same.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • EThirty318i
      • Dec 2010
      • 219
      I should've been more clear.
      Will the rails and crank swap over.
      But since the panels swap over I assume the rails and crank mechanism will also??
      • reelizmpro
        • 9543
        Yes, everything can swap over. I have an 89 M3 with manual sunroof conversion done by the previous owner so I don't know how hard it will be.
        88 M3 - LACHSSILBER
        • EThirty318i
          • Dec 2010
          • 219
          Awesome! thanks for the help!
