Steering wheel foam?
  • Fusion
    • Nov 2009
    • 3659
    I removed the damaged leather from one of my wheels and since some parts were glued like a rock (30y old wheel), small bits of foam also came off.
    Is there something these can be filled in with?
  • Cletonius
    • 2809
    Can you post a pic of the wheel and the damaged areas? I have a couple ideas, did some research on this.
    - Josh
    1990 325is
    Need a shift boot?
    Looking to buy shift boot frames, PM if you have one to sell
    Here's what happens when you let the internet pick your license plate
    • Fusion
      • Nov 2009
      • 3659
      I don't have the wheel here but they're just bits here and there, maybe the size of a half-peanut. Like if you pinched and tore.
      I've thought about using silicone, since it's soft when dried, can be shaped into the hole and should stick nicely.
      • Cletonius
        • 2809
        I think I know what you've got going on, I had some bits pull up on a wheel I'm working on. I've posted on the auto upholstery forum asking for advice; I'll keep you in the loop.
        - Josh
        1990 325is
        Need a shift boot?
        • Cletonius
          • 2809
          Found a couple products: presstocel and plastazote.
          Presstocel is brand name landau padding. Any landau top padding will come in thin enough sheets and be up to the task without degrading.
          Plastazote is a dense closed cell foam, sometimes used for making cutout padded cases.
          The few trimmers I spoke to recommended against using silicone but said either of these foams will work well and have the correct feel. I hope this helps.
          - Josh
          1990 325is
          Need a shift boot?
          • prasina2
            • 117
            you can also buy dense cell foam (similar to your wheel) from a fabric/craft store and glue in the chunks. then shape as you need to with a razor and sanding.
            fb: @WerkstattEuropa
