Plastic bezel removal? (where the radio, climate controls, and computer sit)
  • ipunchfish
    • Oct 2009
    • 106
    I pushed a little too hard on the top right corner of it and it's sunken into dash. How do I remove that part of the car? I'm blanking on what its called.
  • vpilarrt
    • Jun 2006
    • 2096
    Commonly called the HVAC panel. There are 2 screws at the top (behind 2 of the little switches/blanking panels) that screw upward into the dash. There are also 2 screws at the bottom (in the storage well in the center console) that screw upward. If you remove them you can pull the panel forward a little bit. To remove it completely you'll have to remove the radio, loosen the HVAC controls assembly, disconnect the switches along the top, etc.
    • Cletonius
      • 2809
      If you pull the ends off the blend controls and work the center trim out, there will be 4 (maybe 6, I don't remember) screws between the sliders that you can remove to detach the panel from the blend control. Then you won't have to mess with the cables and break all the clips.
      - Josh
      1990 325is
      Need a shift boot?
      Looking to buy shift boot frames, PM if you have one to sell
      Here's what happens when you let the internet pick your license plate
      • ipunchfish
        • Oct 2009
        • 106
        Awesome. Thanks! This is exactly the info I needed.
