Blower Fan/Euro HVAC control
  • downforce22
    • Aug 2009
    • 3189
    Hey guys, I've got an '86 325iX grey market and the damn fan doesn't work.
    I just pulled the whole center console apart to try to get it sorted out and am wondering if you have any ideas. It has the 3 speed HVAC panel and switch. I know the later e30s will directly power the high speed fan setting (fan speed 4) if the resistor is bad, but with this 3 speed I am not sure if mine will directly power it. I checked the resistor and it looks good, no breaks.
    I heard fuse 20 could be the culprit as well, but is there any other relay or switch that could be causing the problem?
  • downforce22
    • Aug 2009
    • 3189
    Found fuse 20 to be blown. Will test it when I get it back together.
    • downforce22
      • Aug 2009
      • 3189
      Decided to test it. Fuse was blown and now it works! This thing blows like a window fan! Only problem is that it is noisy. Is there any way to get this thing to quiet down?
