Sport Seat Disassembly Question
  • Spaceman
    • Jul 2013
    • 140
    How do I remove the knob that moves the front part of the seat base backward and forward? Does it just pull off? I've tried pulling but it doesn't seem to want to budge. See in pic:
  • Chessmaster
    • Jun 2012
    • 501
    For the leg extension, yes its should be pulled off (use two flat heads). Im staring at a bare sport seat frame and there no other method of attachment other than friction and pressure.
    • Spaceman
      • Jul 2013
      • 140
      Thanks. I thought that was probably the case. Appreciate the help.
      • td325ic
        • Feb 2006
        • 788
        A quick and easy trick if you have two hammers is to use the claw end of the hammers and pry on opposite sides of the knob. The knob will pop right off with little effort
        • Spaceman
          • Jul 2013
          • 140
          Worked like a charm!
          Thanks!!!
