MTECH 2 Steering wheel
  • mtlbloodshot
    • Jul 2011
    • 761
    I recently purchased a MTECH 2 steering wheel and the horn button is slightly titled to one side. The bottom of the horn button is not aligned properly with the bottom of the steering wheel. Is there any way the alignment on the horn button can be adjusted?
    MY BUILD THREAD
    http://www.r3vlimited.com/board/showthread.php?t=235231
    INSTAGRAM : @luchcolaneri
  • reelizmpro
    • 9533
    I remember this wheel. I said it was probably bent but the seller said it wasn't. My logic is, why else would the horn pad be cocked to the side? There's no proper way to adjust the center part but what you can do (but you shouldn't have to) is shim the mounts with folded paper or something so that it sits in the right position.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • mtlbloodshot
      • Jul 2011
      • 761
      I think if I would shim, I would have to shim the top right one to bring that side down.
      MY BUILD THREAD
