Threaded shift knob adapter?
  • hasback
    • Aug 2013
    • 111
    I can not seem to track one done in a thread pattern that's useable. like 12x1.5 10x1.5 ect. can anyone send me a link if there is such a thing. im going from e30 shifter to the set screw adapter is what im after.
  • glnr13
    • 1334
    not the threading you requested but it's a threaded adapter.
    • hasback
      • Aug 2013
      • 111
      Seen that one. I don't want to run that one. Hence my post. Thanks for reply though.
      • Liquidity
        • May 2014
        • 395
        The shifter is 14mm in diameter. How do expect to find something that's 10 or 12mm?
        • hasback
          • Aug 2013
          • 111
          m12 is probably the largest standard size for most shift knob manufacturers.
          • AndrewBird
            The Mad Scientist
            • 11892
            More importantly, why do you want to do this in the first place?
            • 15Michaeljoseph
              • Aug 2013
              • 1693
              the alien heads from autozone only come with threads now
              --Mike
              (OO=[][]=OO) For Life
              • hasback
                • Aug 2013
                • 111
                I would like to purchase other aftermarket shift knobs instead of the 10 most common ones I see on everyone's car. I feel it will open my options greatly by switching to a threaded style. All the oem BMW ones are boring or simply aren't heavy enough or to my likeing.
                • hasback
                  • Aug 2013
                  • 111
                  solved my own problem... cut the shifter down a bit. drilled and tapped the shifter to m10x1.5 and inserted a m10 stud. problem solved. works great and now i can buy more common knobs with some more weight. if anyones looking to do the same dont be discouraged. just take your time.
                  • Vincent Brick
                    • Feb 2013
                    • 879
                    Thank you. I was on the exact same search recently for the same reason. I like a plain white ball, or bulbous white delrin. I have the resources, I contemplate making a run of something similar to the part linked above but in a common common thread with a nice taper into a shift boot retainer.
                    I have intended on doing this once I find a deal on a Z3 shifter rod.
                    1991 325i Sport - Calypsorot Metallic - DAILY DRIVEN
                    WTB in SoCal: 8"/10" Lukebox, leather Sport steering wheel, 60L MotoMeter fuel gauge, Thule/Yakima roof rack
