removal of sunroof
  • digger
    • Nov 2005
    • 6201
    removal of sunroof
    i have an annoying rattle inside my electric sunroof of my E30 325is. How do i remove it or open it up so that i can see inside?
    Thanks
  • Kip
    • Feb 2006
    • 183
    Where in sunroof?
    Front? Back? When open or closed?
    Use search function!
    88 325is FOR SALE
    89 325i FOR SALE
    95 LR Disco
    98 Volvo V70XC -FS!
    25' of oil-stained driveway
    Travel Kit:
    M4, FS 92, Mk19, 998
    • digger
      • Nov 2005
      • 6201
      Originally posted by Kip
      Where in sunroof?
      LHS when closed, when open i'm not sure. Found out how to open it but is there anything that commonly comes loose to cause rattles?
      • Scott314
        • Jan 2005
        • 287
        Probably the crossmember inside the sunroof slapping against fabric of the headliner panel. How to fix it? Turn the music up a notch.
        My fast says: traction control is for the faint of heart :evil:
        • DrMcDave
          • 1793
          slide panel back halfway
          unclip headliner panel from metal panel (see front edge of panel)
          slide headliner panel back into the "roof" portion
          close sunroof, and tilt up
          remove 6 torx bolts
          done
          • VAPORBLADE
            • Sep 2006
            • 1771
            Is this how you remove the sunroof? Is it really that simple? I need to take mine out for paint.
            Thanks!
            '89 "is" = M technic II build mode.
            • M42Technik
              • 9781
              Yep thats it.
              Reminiscing...
              • T.Dot_E30
                • Mar 2004
                • 286
                could be the tabs are rusting off causing something to come loose and rattling.
                Hopefully its not that.
                • Coco Savage
                  • Sep 2007
                  • 1039
                  remove 6 torx bolts
                  done
                  i cannot get the interior panel to slide back at all...any trick?
