Shifter knob falling off
  • MatRacer
    • 562
    i have a shifter knob with three set screws and it´s always untightening... Will loctite be enough? What are you guys doing with this?
    E30 now S52
    2008 Suburban LTZ (Family and TT hauler)
    325xiT (Sold)
  • LJ851
    • 7919
    Loctite helps, i have had better success with set screws that don't go all the way into a point, like these.
    Lorin
    The M30 is God's engine.
    • MatRacer
      • 562
      One out of three is like that... Will Replace the two others if loctite doesn't succeed, Thanks!
      E30 now S52
      325xiT (Sold)
      • TimeMachinE30
        • Jun 2014
        • 3749
        My home depot has a nice selection of random fasteners I used to solve the same problem. Check yours!
        ACS S3 Build / Dinan 5 E34
        • AndrewBird
          The Mad Scientist
          • 11898
          Take a drill that is just small enough to fit through the threaded holes in the knob. With the knob sitting in place, drill a small divot into the shift lever. This will give something for a pointed set screw to "lock" into. Then use thread locker to keep the set screws tight.
