Peel&Seal vs dynamat
  • Stanley Rockafella
    • Aug 2011
    • 4056
    Is P&S a suitable replacement for Dynamat? Anyone use either product? I'm mainly thinking floor, trunk (when the OEM tar is removed) and maybe doors?
    Seriously considering this stuff...esp from the reviews. Would have to pick up a few roles next time Im in the US
  • AndrewBird
    The Mad Scientist
    • 11898
    I've used it several times and it work great for dampening vibration and blocking heat. Don't expect it to block sound passage though. What exactly are you looking for it to do?
    • george graves
      • 19992
      I did the floor/firewall of my car. It makes it a bit more "solid" feeling in a way - mostly just by the sound of the road.
      Read the reviews carefully. Some of the cheap stuff will "outgas" and leave your windows with a foggy coating for years after install. PITA.
        • Aug 2011
        • 4056
        mostly noise. It would be under the carpet and in the doors etc/
        sucks about the "outgas" thing. I'll have to look carefully for that
        thanks
        • MoreMayhem
          • Feb 2012
          • 649
          There are other brands that are very similar to Dyna but less expensive. I used one called fat mat that seemed to work fine. no outgassing that I noticed, but I used it in the trunk. It did make the car smell like a petrochemical factory for a few weeks.
          • Van Westervelt
            • 9365
            GT Mat, Roadkill etc.
            I just bought some GT Mat to try out. It is much cheaper, comes in 3 thicknesses and has no branding. It looks to have a high butyl content, but not as high as Dynamat, which I like because its easier to handle and not as messy.
            • E30NJ
              • Aug 2013
              • 921
              What was that thing about dynamat leaking out messy oil if it gets like ~100 degrees?
              • robrez
                • Jul 2008
                • 3376
                Do you need to remove the dash to get effective coverage from engine bay noise/heat?
                January 2012 COTM
                • george graves
                  • 19992
                  Best way to quite engine/tranny is to stop it *before* it's in the cabin/metal of the body. The factory heat shield/sound blanket is very effective. I know cause I removed mine, and wish I hadn't. No amount of "dynamat" will make up for it on the wrong side (from the inside) IMHO anyways....
                  • jeffnhiscars
                    • Jun 2011
                    • 6010
                    P&S being a roofing product, is made from asphalt and will in fact out gas. I might consider using it in the trunk or doors but would avoid it in the passenger compartment for obvious reasons. I did my Tacoma w raammat which is a comparable (to dynamat) butyl based product only way cheaper so worth checking out.
                    The other thing is that these products are NOT block noise but they reduced harmonics, which is the drumming that drives you nuts. It is only helpful to cover the centre 25% oo so of the unspported area, so outer door skins but much smaller sections of the floor which is structurally reinforced. Anything more just adds weight and is a waste of $$.
                    For noise itself a thin sound absorbing foam does wonders...ie inner door skins, headliners etc
                    Alice the Time Capsule
