Garmin won't plug into cig lighter
  • Stanley Rockafella
    • Aug 2011
    • 4062
    Anyone upgrade to a smaller diameter lighter socket that'll hold power accessories?
    On my e30, the socket is slightly too big and won't hold the charger in place very well
    thanks in advance
  • Ray Smoodiver
    • Jun 2004
    • 8809
    Just use a sleeve.
      • Aug 2011
      • 4062
      thanks, but no.
      im looking to replace the whole socket
      • StereoInstaller1
        GAS
        • 22679
        Shove a thin screwdriver under the side terminals, bend them out gently so the stupid thing stays as it should.
        Parts stores have "Accessory Power Sockets" and lighter sockets, both around $5, none of them will fit for shit off the shelf, but some high-grade crazy glue and you should be good to go. You may need to use the plastic grommet it came with, but its a hour project, tops.
        My question is why you got wires dangling? That shit is strictly amateur hour bud, get that shit hardwired.
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
          • Aug 2011
          • 4062
          Lol, I gotta use the same garmin for two different cars. Easier to swap between cars.
          Is there any way I can just get the OEM socket and replace it? I've removed the housing the lighter socket sits in, but I can't seem to remove the old one (really fused in there!)
          thanks again for the help
          • StereoInstaller1
            GAS
            • 22679
            So, I apparently didn't explain the "fix" very well.
            You can just pry out the tabs on the sides of the Garmins plug so it fits tighter in the BMW socket, it only takes a second.
            Closing SOON!
              • Aug 2011
              • 4062
              thanks for the help so far
              The problem is with the metal tab at the bottom of the lighter socket. It doesn't make a good connection when the accessories are plugged in. Which is why i wanted to replace the whole socket
              So in my rush to remove the socket, I failed to see if BMW actually sells the socket alone, and so far I'm coming up with nothing :( I'll see if I can get one from a MINI to fit
              http://www.ebay.co.uk/itm/Used-Genui...item35dca182a6
              thanks for the help so far :)
                • Aug 2011
                • 4062
                I might be in luck
                61 34 1 367 690 :) only avail at Bavauto
                now if only i can find a way to make my old light ring attach, I'll be set :D
                • Vincenze
                  • Apr 2019
                  • 1034
                  Originally posted by Stanley Rockafella
                  I might be in luck
                  61 34 1 367 690 :)
                  Does the cigarette lighter socket 61341367690 fix your problem?
                  Mine is a little bit big too.
