Cabrio front window gap adjustment?
  • THEhomelessONE
    • Oct 2013
    • 303
    Downloaded the Bentley manual and it wasn't much help. The front windows leak near the very front of the top. There was a screw that could adjust the tilt of the front windows but couldn't find a screw to adjust the height. The window brackets don't use bolts but silicone instead. It's a 92, maybe they changed from bolts to silicone
    It looks like the regulator/motor has enough teeth left to seal the gap, but how can I make it relearn? Tried unplugging it while the window was down as well as up but made no difference. I know the PO changed the top with another used one, and the car it came off of had the windows adjusted higher.
    RIP 02/25/15
    http://www.r3vlimited.com/board/show...16#post4356816
  • Semblance
    • Jan 2011
    • 433
    I have the same problem and was looking at this:
    Seems to indicate vertical adjustment. But I'm also wondering if my top seal is just shot. It looks a bit deformed
    '89 lachssilber vert - Frau Blücher
    '84 alpine 2dr - gone to the great beyond...
    '00 titanium 4dr e46 - bricked
    • THEhomelessONE
      • Oct 2013
      • 303
      That's a great link thanks! Yeah my seals don't look great either, shoved a piece of an old 528i badge I found in the trunk from PO in between the seal and top frame, works for now lol.
      RIP 02/25/15
      • rcsoundn1
        • Nov 2012
        • 3361
        Mine also does the same thing. I heard covering the seals in Vaseline helps plump them up a bit.
        • Todd Black 88
          • Oct 2007
          • 3449
          I found on my 92 mtech, that the link provided above did not apply to my car. Not sure if something changed around that time or not.
          I found that there was an actual physical stop attached to the lifting mechanism that contacted an adjustable bolt on the door, when at the top. The bolt was adjustable up and down, thus letting the window rise more or less untill hitting it.
          Originally posted by codyep3
          I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
          2001 silver/Blk 325 cabby. SOLD
          2002 325xit Sil/blk. SOLD
          2010 F650gs twin
          • THEhomelessONE
            • Oct 2013
            • 303
            This is what my 92 has as well, but I noticed it only adjusted the tilt at the rear of the window. Problem I was having was towards the front half of the window.
            RIP 02/25/15
