Need some help. I've got a Momo 2006 steering wheel hub, and I can't get it to slide all the way on the spline. It goes about half way and then it feels like I would have to force it. The Mtech 2 I have comes on and off easily and I also know about the key/ignition lock and have removed the white pin. My car is a an airbag car (1991 318is) Any input is greatly appreciated.
Momo Hub Issue 318is
1991 318is S52
1987 325i Vert
1991 325i
2011 e70 X5
Need Anything E30? -> http://www.gutenparts.com/Tags: None -
1991 318is S52
1987 325i Vert
1991 325i
2011 e70 X5
Need Anything E30? -> http://www.gutenparts.com/Comment
Okay, I ordered another Hub, thinking the splines on the first may have been messed up. If this new one doesn't work then obviously it's an issue with my setup. The old hub only went on 1/3 of the way and left about an inch gap between the hub and the steering column.
1991 318is S52
1987 325i Vert
1991 325i
2011 e70 X5
1991 318is S52
1987 325i Vert
1991 325i
2011 e70 X5
I put one on the 318is i had but it was a few years ago and i can't remember exactly what i did. I do remember grinding a bit and using some washers to space the wheel back. Sorry i can't be of more help.Comment
Well I found that the Momo hubs I ordered worked fine on my buddies car. So it looks like my spline is shot.
Is number 1 the part I would need? Anyone swapped this before?
http://www.realoem.com/bmw/showparts...48&hg=32&fg=30sigpic
1991 318is S52
1987 325i Vert
1991 325i
2011 e70 X5
Anyone?sigpic
1991 318is S52
1987 325i Vert
1991 325i
2011 e70 X5
Buellersigpic
1991 318is S52
1987 325i Vert
1991 325i
2011 e70 X5
1991 318is S52
1987 325i Vert
1991 325i
2011 e70 X5
Greg, the whole column has to come out for that... fair amount of work. I have a spare steering column from a parts car with good splines if that truly is the issue.IG: deniso_nsi Leave me feedback here
