Check Panel Delete?
  • UlrichFennec
    • Dec 2014
    • 1268
    Check Panel Delete?
    I'm looking for a dead plate to cover up my check panel so it doesn't have a wire cluster hanging down from it. Anyone know where I can get my hands on one?
    "Leafeon" '92 Lagunengrun 325i Vert (Daily Driver/Project)
    http://www.r3vlimited.com/board/showthread.php?t=366044
    The stickers make it go faster. :nice:
  • nau
    • May 2012
    • 14
    63311376895 - that looks like what you need. Pricey however.
    • ButtJuice
      • Dec 2009
      • 2609
      I have a blank 318is one.
      1991 318is - Sold
      1986 325 - Sold
      Instagram - Lamoursum
      • jalopi
        • 2370
        jaywood makes a shit ton of panel delete things for these cars. i'm sure he can bang something out for the check panel for you
        • AndrewBird
          The Mad Scientist
          • 11898
          Paint a check panel black?
          • ELVA164
            • 4861
            Does it not work? Did you try another panel?
            • ecsk
              • Nov 2011
              • 106
              Why not just buy a used check panel from eBay to cover it, doesn't matter if it work if you don't care.
              • Das Delfin
                • Sep 2014
                • 2293
                I have an extra one you can have. They never worked with my car. But a blank one from a late model 318 would work too.
                What I did was convert to an e34 dome light, which fits perfect on the cabrio once you cut the divider between the stock dome light and the check panel. There is a bit of space below the dome light aftwerwards, but my top panel isn't in good shape and the leather has stretched; it may fare better on yours
                The e34 dome light gets you a center dome light with a map light for each front seat: TONS of lighting over the original. Cabrios are unique in that you don't have to modify the e34 light housing to fit correctly
                • mlbryant8
                  • Jul 2014
                  • 237
                  How did you get the dome light to work? I have done the same but from an e46. I now have the map lights and the ambient light but no dome light. When I wired the dome light, it was constantly on and the switch did not work. But, I love the amber ambient light.
                  2007 X3
                  1992 M Tech Cabrio
                  1988 Cabrio - sold
                  2001 X5 - sold
                  1997 e36 328 - gave to son
                  • Das Delfin
                    • Sep 2014
                    • 2293
                    The e34 dome light has 4 wires: two are ground, one is power from the door switch and one is power from the light switches. You just have to look at a wiring diagram for the e34 and a diagram for the e30 and figure out which of the two e34 wires are ground. Then you can splice them together to connect to the single e30 ground. It's really easy once you know the colors. I did have to sand every single contact on my e34 dome light, though.
