Swapping tachs problems!!
  • MRosen21
    • Jun 2015
    • 28
    I need some help I am doing the E to I head swap and I need a 7k tach since the stock is only 5 in my 87 325. I bought a 7k motometer tach (mines also motometer) and the tach itself wont even fit in the board and the connections are different.. Is there a specific numbered one that i need for the swap ?
  • reelizmpro
    • 9552
    There are differences between the 84-85 clusters and 86-on. It could be that you have an 84 318i tach (also 7k). You need to post pictures so we can see what you have.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Reichart12
      • Aug 2012
      • 2165
      I had made a thread about the same problem not too long ago and Nando was able to help. The differences in tachs also create a difference in coding plugs. For me the small back tach I needed used the coding plug in the front of the cluster. I found the correct tach and matching "17" labeled plug and all was good.
      Instagram: Reichart12
      • MRosen21
        • Jun 2015
        • 28
        [IMG][/IMG]
        • MRosen21
          • Jun 2015
          • 28
          [IMG][/IMG]
          • reelizmpro
            • 9552
            Okay, how about a pic of the back of the tach? Another thing...don't trust what the cluster says on the outside. See what is printed on the main board. Sometimes people will change things around.
            88 M3 - LACHSSILBER
