Best product to repair forward center console?
  • The Dark Side of Will
    • Jun 2010
    • 2796
    There's a small chunk missing from my forward center console where the tabs from the rear center console engage it.
    What's a good product to repair this/build it back up?
    • Jun 2010
    • 2796
    This is what needs to be filled:
    I've already fixed the crack to the right with some fancy industrial glue, but I'm not sure it's the right stuff to try to do a "bulk" fill of the missing area.
    • AndrewBird
      The Mad Scientist
      • 11898
      Expanding spray foam from like Home Depot is the same material. Buy a can and squirt a bit in there, then trim it off after it drys. I would mask off the surrounding area first (on the front) and only use a tiny bit as that stuff expands a lot more than it would seem.
        • Jun 2010
        • 2796
        The Home Depot stuff is *WAY* less dense than this urethane.
        Anyway... I found this in a dive shop and used it for S&G's:
        Duct tape form for the glue:
        Fully cured glue:
        It's pretty tough stuff already!
          • 34839
          I think there are 2 densities of the expanding foam. I think it would have worked too, but that shit can be messy..
            • Jun 2010
            • 2796
            I used White Gorilla Glue. It's a urethane adhesive that expands from a liquid into a foam as it cures. It appears to be pretty much the ideal adhesive for this purpose.
