Heater not working after HVAC bulb change?
  • Brian7
    • May 2013
    • 129
    Pulled my center dash out to change the HVAC bulbs, put it all back together and now the heat blowing at my face only blows cold. What gives?? The heat worked fine yesterday before I pulled the dash apart. The knob won't go full cold so it seems like a mechanical linkage that disconnected maybe?
  • jeffnhiscars
    • Jun 2011
    • 6011
    FYI you only need to remove the radio to change those bulbs. I'm guessing you did not reconnect all the Bowden cables
    Alice the Time Capsule
    • Das Delfin
      • Sep 2014
      • 2293
      • Brian7
        • May 2013
        • 129
        Yup pulled it back apart and the knob was disconnected from the cable. All fixed
