Custom camel / burberry interior
  • sert57
    • May 2014
    • 170
    I updated my build thread already but figured I would post here as well. I know its not to everyone tast but I am very pleased with the final results.
    In January I had never touched a sewing machine before. I had amassed a small collection of 4 sport seats in various state of repair, and I knew I eventually wanted to have a nice set, maybe with some plaid :)
    In february I purchased a sewing machine and other tool, and began to work on one of my sports seats using a cheap vinyl from hobby lobby. During this I created patters from the dissasembled seat, and figured if it turned out I could use the patterns later.
    With these results I purchased a hide of leather (https://www.leatherhidestore.com/chi...ther-hide.html)
    and 4 yards of burberry plaid fabric that I had professionally backed for upholstery used
    (https://www.fabric.com/buy/0479617/f...ll-plaid-acorn)
    I used the patterns I made on the vinyl seat and recovered a good driver and passenger seat, and replaced the seat shocks and cleaned / lube dhte mechanisms in the process.
    I used SEM camel paint on the door cards and seat backs and was pleased with the outcome.
    I moved onto the rear seats using the same method I had with the vinyl seat, and was pleased with the results. I also made a shift boot pattern from an existing torn up boot I had, and made my own pattern for an E-brake boot / cover. I was incredibly pleased with how these all had turned out. I was visiting a friend and spoke to his mom about my project, specifically if there was any way to put fabric on the door cards, and she recommended some flexible tack strips. I used these strips ( had to buy another 1.5 yds of fabric) and after the finger cutting and arduos install process had some matching door cards!
    Ill let the results speak for themselves, Im incrediby pleased for my first attempt at this. there are lots of small flaws here and there, but nothing that stands out too much.
  • Mook613
    • Apr 2016
    • 232
    Nice... Bit of a tip with the French Seams, either mark the entire line before stitching to make sure it's straight or use a twin leather needle.
    Sent from my SM-G920W8 using Tapatalk
    • sert57
      • May 2014
      • 170
      Thanks! Yeah I never really figured out how to do them the best, I'm sure if I were to do it again i would try a few other ideas to keep the seams straighter
      • cncmastr
        • 206
        Go you! That's pretty ambitious! Props!
        E30 | E46 | E53 | F31
        Collection of my DIY Guides here
        • shootnjunky
          • Aug 2014
          • 506
          Nice work, you should be proud
          • Das Delfin
            • Sep 2014
            • 2293
            Looks great! Love the door card accents
            • IceWhite
              • Jan 2015
              • 945
              Great colour scheme. That came out really good!
              1990 325i
              2004 330i Individual 6-speed
              • tim88325is
                • Jul 2008
                • 201
                Looks great!! Did you need to get a heavy-duty sewing machine for the leather?
                • sert57
                  • May 2014
                  • 170
                  I used a singer 4411 with 110/18 HD needles ( Still not sure how needle ratings work tbh, but I'm sure its simple).
                  The biggest issue had to be when i sewed the plastic clips into the leather and also when I sewed the rear bench together, I was going through something like 3-4 layers of the leather at some point, it was ridiculous.
                  • glnr13
                    • 1334
                    much respect. sewing leather is no easy feat and you did it without a walking foot, props.
                    • sert57
                      • May 2014
                      • 170
                      Oh no i had a walking foot attachment i purchased for the machine ($7ish) that helped a ton
                      • tim88325is
                        • Jul 2008
                        • 201
                        Cool, thanks for the info!
                        How was doing the thigh support area? It seems to be complicated with different panels...?
                        • sert57
                          • May 2014
                          • 170
                          The thigh support panel ( I assume that is the piece i have called the "legrest" that slides out the front of the sport seats) wasnt really any harder than the headrest. I think the toughest part was getting the small leather linking piece that attaches it to the main lower center to line up just right.
                          The tighter radiuses compares to the headrest make it harder to be consistent with, but not too much harder
                          • jeffnhiscars
                            • Jun 2011
                            • 6011
                            What did you use as a backing for the fabric door inserts. Im doing my doors now and would appreciate the feedback
                            NM I found 1/8 Masonite which should be ideal
                            Alice the Time Capsule
                            • cspec
                              • Apr 2017
                              • 182
                              Do you mind sharing the general overview of how someone would go about doing this? Interested!
