Pre-Facelift Interior Query
  • TheWolfman
    • Sep 2018
    • 19
    Hi,
    I’m the owner of a 1984 320i Baur and was just wondering whether anyone knew if the pre-facelift e30 was fitted with speaker/kick panels?Currently my vehicle doesn’t have any and just has a ‘speaker grill’ over the side panel speakers.I would really prefer to have kick panels as the carpet just gets kinda scruffy down there.... :roll:
    Found some E30 ones but not sure if I can actually fit them though...any input would be appreciated.
  • kronus
    • Apr 2008
    • 13028
    yes, all E30s had kick panels in the interior.
    cars beep boop
    • TheWolfman
      • Sep 2018
      • 19
      Aha,thanks for the confirmation on that,I suspected that was the case but wasn’t sure.
      Time to buy those kickpanels then I guess....
      • Baur
        • Apr 2011
        • 12
        With kickpanels you mean the panels in front of the doors? Pre september 1985 didn´t have them, at least not in plastic. They where made of the same fabric as the floormat. The speakers went behind them.
        Gr jeroen
        • TheWolfman
          • Sep 2018
          • 19
          Ohhhhh...I’ve just seen this Baur,sadly after I just spent €50 on buying some kick/speaker panels based on the above advice...
          Yes,my baur currently just has carpet with a speaker ‘cover’ which is just a bit larger than the speaker itself...I just assumed the kick panels were missing...I wonder if the ones I’ve purchased will fit anyhow?Or if not,anyone want to buy some??!
          • kronus
            • Apr 2008
            • 13028
            Gr jeroen
            I have a 6/83 build car that came with them.
            cars beep boop
            • IceWhite
              • Jan 2015
              • 945
              I had an '84 with the carpet and speaker grill.
              1990 325i
              2004 330i Individual 6-speed
              • TheWolfman
                • Sep 2018
                • 19
                So this now all seems to be somewhat ambiguous,question is can I fit them whether it had them originally or not I guess
                • TheWolfman
                  • Sep 2018
                  • 19
                  Well,the suckers have arrived already and as far as I can tell they are mounted only via one screw which goes into the speaker screw holes.... let’s see what happens
                  • ANDRÜ
                    • 1020
                    My 84 320i (euro also) has the carpet kick panels like you describe.
                    • TheWolfman
                      • Sep 2018
                      • 19
                      Well I can confirm that the later plastic kick panels do indeed fit.Kinda crazy that there are only attached by one screw...but hey,who needs to use 4 when you only need 1 eh?!
